HDMI ports on the back of the TV have pushed in!
Hello:
I have an LG47LN5750 and while swapping out my Playstaion 4 with the Nintendo Wii u, the HDMI port was pushed into the casing of the TV.
I then attempted to use HDMI 2 and the same thing happend.
Luckily, HDMI 3 worked without incident. I have swapped out other components before so I am not sure if I wore out what holds the port in place or whatever.
Is there a way that I can just remove the back case to this TV and put them back?
What is holding them in place?
Thanks for any help,
Paul
11 commentaires
Please, smart guys (or gals) help us with this question. i think I see a way in to reset the HDMI input but am not sure about it. Thanks to all. es335 John Brown
par lpcustom79
take apart the tv and take a picture of the board were the HDMI is and we will see what is best for the repair. please be patient for a reply.
par _Z_
Hi there, if you can take the back cover off and see what has happened when you pushed connector in, might be able to push it back into place if it has not damaged the PCB is mounted to it. If it has a cable on the back you might have damaged the clips that hold it into the back casing. If that's the case you might be able to epoxy it connector into place. if you have pushed PCB back see if you can use some rubber or plastic to provide a support spacer to hold it into position. You need to open it up and see whats what. Regards
par Willy Pittner
I have just pushed in My hdmi input I have 60inch tv is is possible to fix it.
par emma spanswick
I fixed mine by watching a youtube video. I had never done anything like this before so it was a bit nerve racking in a way.
I had to purchase the "logic board" of my LG 47" (about $60.00) beforehand.
The part that breaks or pushes in, is not all that secure so if you do open it and get a chance to look you will see what I am talking about.
Hope this helps,
par Paul Squillace
Voir 6 commentaires en plus
