Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Krups single trigger coffee grinder identified as style F203.
motor works but blades only spin if grinder is unloaded
The machine seems as if it's working with no load or with very small amount, but as soon as I put in a normal amount of material to be ground then the blades do not turn. It's like whatever connects the blades to the spinning shaft has failed or does not engage properly. Also how do I get the blades off?
Répondu ! Afficher la réponse J'ai le même problème
Indice 5
1 commentaire
The blade screw is stripped. I have the same problem. I can’t find a replacement blade.
par
Ajouter un commentaire
1 Réponse
Solution retenue
the blades can be pulled off, pull hard,because the thread inside the plastic blade hub has stripped. Penny pinching on Krups part! you will now have to glue the blade back in place-epoxy resin worked for me.
Indice 4
3 commentaires:
Worked a treat, many thanks.
par
Easy fix that worked. Thank you
par
Worked Great!! Thanks!!
par
Ajouter une réponse
tanya sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 55
Total : 3,447
