Aller au contenu principal
Comment réparer la PlayStation 4, console de jeux télévisés produite par Sony Computer Entertainements, également connue sous le nom de PS4. Annoncée le 20 février 2013 et lancée sur le marché le 15 novembre 2013.
20 questions Voir tout
Is my ps4 broken
Hi i recieved the ps4 for xmas from my wife so its now only 3-4 months old,the power inlet is slack and therefore is a real pest to get the system up and running when i eventually get going it with no warning cuts off after 20 mins maximum im now really concerned about it.is this something i cood repair myself?because i no longer have the reciept for the playstation and am worried that its been a waste of money
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
The bad news is that yes, there is something wrong with your PS4. The good news is that its probably fixable. There are 2 likely possibilities:
1) If the power cord is loose when you plug it into the PS4 then that could be creating a faulty connection when the console is turned on and you are using it. If this is the case then you would either need to get a new power supply or find someone to fix the power supply. My business can repair most power supplies and there may be others out there as well.
2) Sometimes when a PS4 turns off randomly it's because the solder joints under the APU are faulty. If this is the case it can usually be fixed as well.
I hope this helps.
Indice 2
Ajouter une réponse
jock sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 442
