Out of balance during spin cycle?
I have a Samsung washing machine, model# WF350ANW/XAA01. It starts out out of balance, during the spin cycle, The tub moves out of the circle all thru the spin cycle. Is there a "fixit" for this, without a repairman?
7 commentaires
Was it out of balance when nothing was/is in the spinner?
par Terry Parker
mine doesn't go off balance when empty
par reenycq
Mine will not spin unless there is some water to float the clothing.
Once drum RPM is up, THEN the pump kicks on.
Depending on settings, it will repeat this rinse/spin/pump sequence.
It is not a Samsung.
par Tom Shafer
i have a Samsung washer also i have tried everything even up too trying one towel and it spins out of ballance . i have been messing with a sollution and have come up with a kind of bogan way of sorting the outa balance out so my washer spins fine ...
i had 4 old kitchen chairs out the back i took the back cushions off them took the top off my washer and placed them down the sides of the tub front back and both sides put the washer back together and put a doona in too wash and believe me when i say this i was amazed when it actually washed and spun it first go .. well that's my fix no tec guy no cost just 4 old kitchen chair back rests and its good for another year ... i let ya's all know how long it lasts but its even doing full loads now with no hassle
par nathan
My machine spins off balance even when empty. Made a awful noise I turned it off right away smelled a burnt rubber smell with a little smoke come out the top. I took the back panel and top panel off. The belt is fine and all appears fine. I did a spin only cycle and it seems like it may be an issue inside the plastic that houses the drum. It’s a dv203a washer
par rspearcey
Voir 2 commentaires en plus
