Aller au contenu principal
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
Questions au sujet de 111 Voir tout
Why are my brakes locking up on me?
I have a 07 chevy equinox and the stabilitytrak light came on as my brakes started to lock up. Does anyone know what can be wrong. I have changed the booster and the master cylinder and yet the brakes are still locking up.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
4 commentaires
I have the same problem Elantra 2004. I have replaced 2 calipers, brake line hoses and the master cylinder. Flushed the system twice. Yet my front brakes are still locking up. The power booster has no leaks and the pedal does not sink . What else is there?
par
I do not have ABS or traction control. I am at my wits end.
par
You do have abs and wheel sensors don't known that don't touch car
par
Tengo una Equinox 2007 y me pasaba lo mismo, despues de cambiar discos, pastillas y mordazas y todo seguia igual, cambie las mangueras que van a las mordazas, ya que estas estaban parcialmente obstruidas
par
Ajouter un commentaire
1 Réponse
Solution retenue
in both cases Antonio and funkybob this is a symptom of a bad abs pump. You may or may not get an abs light as the pump can be working enough to register but not enough to work properly. Hyundia are bad with there abs systems and there traction control . Chevs have a better system but when the stability control starts acting up on them the first place i look is at the abs pump. Hope this helps
Indice 3
4 commentaires:
Thanks Jim but I do not have ABS or traction control.
par
funkybob does your car have esc light on the dash when you turn on the ignition and all the lights come on just before it starts?
par
It does have and for sure sounds wheel sensor on equinox
par
how big a deal and how expensive is it to check out the abs pump?
par
Ajouter une réponse
Antonio Nieto sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 34
Total : 6,975
