Aller au contenu principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
429 questions Voir tout
iMac Not Booting - Fan spins then stops - LED 2 blinks
Hello, my iMac appears to be having hardware issues. I thought it was a power supply issue, so I bought one from this website, but I'm getting the same issue. LED 1 lights up and stays lit, LED 2 blinks 1 time, LED 3 and 4 both do not light at all. Also, when LED 2 blinks both fans spin for about 3 seconds, then stop. This process never stops as long as the power cord is plugged in to the wall. Ive tried all the typical fixes, reseated RAM, reset SMC, pram, and replaced the power supply. I'm thinking it's the logic board, but I can't find anything online with these same symptoms. Any input would be much appreciated. Thank you
Répondre à cette question J'ai le même problème
Indice 5
3 commentaires
Did what i wrote help you?
par
What ended up being the fault, mine does this problem also
par
I have a service check and they ask for 700$ to replace the motherboard. I throw away
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
The first LED means your power supply is fine.
-it should always be on when the power is plug in.
The second LED means your logicboard is fine.
-it should aways be on when your computer is on.
The third LED means your video card is one.
If your second LED doesnt stay on that means you have a logicboard issue.
Indice 3
Just found the fault. Remove your ram vacuum and clean the slots, clean ram and fit 1 ram at a time, I removed the ram I upgraded 2 years ago now it boots up.
from my research if you still have issues it will be a logic board but check your ram first
Indice 1
1 commentaire:
I had the same problem: upon opening the iMac, found LED #2 flashing about 1 Hz. Replacing the upgraded RAM with the apple original RAM allowed machine to boot. (Wish I had checked this BEFORE spending an hour removing the display and the adhesive tapes!)
par
I had same issue and same led pattern. Like a dummy, I had LCD thermal sensor cable plugged into the unused port to the left instead of the port next to the Display data cable/LCD cable.
Indice 0
Ajouter une réponse
kelaure sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 2,111
