replace the left rear door lock actuator
I need to replace the left rear door lock actuator and it makes a honking noise and does not lock the door.
petersea8 , Jim, The link below shows steps to access the lock to change, a video link and link to replacement part to give an idea of what to look for. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://jeepslimited.com/index.php/write-...
Jim, pretty much teh same idea as on here.
REMOVAL
(1) Remove door trim panel,
(2) Disconnect latch and lock rods from inside handle actuator.
(3) Remove screws attaching inside handle actuator
to trim panel
(4) Separate inside handle actuator from trim
panel.
I looked up how to "Replace left rear door lock actuator", I tagged on the link and got this video on how to remove the door panel, problem is I had already gotten that far and then wound up putting it back on.
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 3,456
