Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Improved second generation Google-branded tablet with a 7" screen.
Nexus 7 2013 Locked up can not turn on
it locked up ,turned off would not restart. while plugged in no battery charging icon visible.any way to turn it on?pressing vol and power at same time has no effect.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Solution retenue
Hi Robert,
How long did you hold the keys down?
For any one else reading this:
Recovery Mode
  • Turn off the Nexus by holding down power button.
  • Press and hold Volume Down and then press and hold Power until the tablet turns on. You should see the word “Start”.
  • Press Volume Down twice to highlight Recovery Mode. Press Power to confirm your selection.
  • Hold down the Power button and press and release the Volume Up button once.
  • Press Volume Down twice to highlight Wipe Data / Factory Reset and press Power to confirm.
  • Press Volume Down seven times to highlight Yes - Erase All User Data. Once again, press Power to confirm.
  • After the reset is finished, reboot your device.
If your Nexus appears to lock up during any of these steps, you can restart it by pressing and holding Power for a few seconds.
Some mess up the above and get 'no command' and the android guy on his back on the screen.
Try this:
Hold the power key and tap the volume up key. then release the power key. This will get you to the next step. That is the command it is looking for. It is an additional step to make sure someone does not enter this mode by mistake.
Indice 3
Ajouter une réponse
robert jaffe sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 42
Total : 807
