Aller au contenu principal
A handheld digital pet that was first sold in Japan in 1996.
Questions au sujet de 3 Voir tout
My Tamagotchi is still not working after a battery replacement?
I put a new battery in but it is still not working, so what else can I do so it can work and be played?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
Seriously, what is the gadget you're talking about? Are you sure that the problem is the battery only? Please complete questions so that you'll receive helpful answers.
par
set it on fire....................................................
par
Ajouter un commentaire
3 Réponses
Solution retenue
The mains problems with tamagotchis are :
  • oxidized pine (if you forgot the battery in it for 20 years ago… or buy it new. usually that’s not a problem with bandaï ones, but with odd pets) you can fix it by remove the rust with a q-tip with vinegar
  • bad contact from screen or battery . make sure the more screw you still have are well screwed.
Hope it will help someone
Indice 2
I suggest making sure you inserted the battery in the right direction. I know this sounds like a simple thing, but someone I know did a similar mistake and ended up throwing it away when the solution was so simple.
Indice 0
Maybe reput the battery’s in if not get a box of new battery’s so it will work better 👏👏👏
Indice 0
Ajouter une réponse
Frog sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 42
30 derniers jours : 168
Total : 4,296
