Aller au contenu principal
Repair guides and support for the 2nd-generation Renault Mégane, also known as the Renault Mégane II.
Questions au sujet de 17 Voir tout
How to replace the timing belt
how to timing the car?
Répondre à cette question J'ai le même problème
Indice 4
1 commentaire
Hi, my 2004 renault megane is making a grrrr sound when idling and driving.
My belt has alota fine cracks. What can be the problem?
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
Oh dear you need the special can locking kit with the tdc locking pins ,Reno's are a ##&&% to work on I know I got a modus 1.6 its the same set up ,they also use a dephaser cam gear so if it starts to make a rattling sound on start up get it changed , only use synthetic oil and change the filter twice a year because they are so small , buy a can of silicon spray and spray every electrical connection and fuse box ,these things are prone to damp ,
Hope it helps you ,good luck !
Indice 1
There is a perfect book for repairing this car on your own. Give it a try
https://haynes.com/en-gb/renault-megane-...
Indice 0
I changed the timing belt a few years ago. I didn't use any locking kit. The hole to lock it is inaccessible. It looks possible in the Haynes book but it isn't. I marked up everything with a white pen and took the chance of nothing moving. It worked fine and I saved 500£/€\$. I took my time when I didn't need the car.
Indice 0
4 commentaires:
You cannot do this with the diesel engine variants without running a real risk of the camshaft moving relative to the camshaft Marking the parts simply doesn't work as the crankshaft pulley is not keyed the the crankshaft on the diesels.
par
@cjrc your diesel has a timing belt? What engine is this exactly?
par
@cjrc Awesome and I just found the tools for it as well. I thought it was uncommon for a Diesel to have a belt vs a chain but I guess Nissan/Renault built a pretty good engine with it.
par
Ajouter une réponse
reza sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 33
30 derniers jours : 156
Total : 9,340
