Ford e250 van sputters/dies after heavy rain wont restart after dryin
Ford e250 cargo van
checked all fuses all good little water found on wire harness and close to a some box on top with 3 wires coming out
Ford e250 cargo van
rking, No start condition after heavy rain. This is a probable cause of distributor cap/rotor condensation causing erratic spark, pull cap, look for moisture, wear/hairline cracks and corrosion. If cap looks OK spray with electronic wire dryer or some product that will displace the moisture, cap may just not sealing on base.
Also spray really well, all plug wires, coil, control module and any other wires/plugs that have to do with ignition. Good luck.
Check for sparks when starting up engine. Look at spark plug wires. May have cracks and or other wear. Look at distributor cap. Timing adjustment door may be missing or stuck open. Hope this helps.
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 19
Total : 997
2 commentaires
A little vague there. locate the box, Drivers side? and markings.. I.e. Part Nums Wire colors. try WD-40 to dry contacts?
par dshort2001
Is this problem repeatable? It sounds like it rained once and the van died permanently but if that's the case diagnosing is difficult.
par roleplayingencyclopedia
