Aller au contenu principal
First generation of Citroen's supermini car.
Questions au sujet de 20 Voir tout
refill of C3 Aircondition system
How much R134a oil contains the aircondition system on an 2003 Citroen C3 1,4 HDI 16 Valve (92 hp) ?
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
Solution retenue
This is the best info I could find. If you need to know the exact amount of oil there should be check your local library for a Chiltons manual for reference. I hope this is of some use to you. Ralph
http://reviews.ebay.co.uk/Citroen-C3-Air...
Indice 5
2 commentaires:
+ nice
par
Hi Ralph ,Thank you very much for your answer, after checking at my local library , I found out that the right amount of R134a was between 0,575kg and 0,625kg , the amount in the system was 0,320kg , and the air temperature in air-outlet was about 11 degrees celsius, after refilling to 0,600kg , it was about 4 to 5 degrees celsius , so quite a difference. Best regards Finn
par
Ajouter une réponse
Finn sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 4,779
