Aller au contenu principal
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
Why does my Pontiac keep loosing power and shifting hard
will run fine then starts acting up.if i turn it off and restart it runs fine for a while looses power
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Check your trans fluid level. This is done when the motor is running and warmed up,check the smell of the oil If it smells burnt there could be more problems.Check the color it should be pink (Red) if its browning change it. hope this helps
Indice 3
2 commentaires:
Are you a mechanic I see you posting on a lot of these car questions?
par
I worked for a lot of years as a heavy truck mechanic as well as light auto but now I'm working in robotic repair and maintenance
par
Ajouter une réponse
carlbishop66 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 126
