Aller au contenu principal
Repair guides and support for LED, LCD, HD and other Vizio TVs.
Questions au sujet de 892 Voir tout
My vizio tv comes on but no disply
my vizio m3d460srp 3d tv comes on but but no display i can see the menu but very faint i also can see the glow through the back of the tv in a dark room
Répondu ! Afficher la réponse J'ai le même problème
Indice 5
Ajouter un commentaire
2 Réponses
Solution retenue
larry, "see the menu but very faint i also can see the glow" means your backlight is out. This could be a PSU issue for simply not supplying enough power to your backlight. The next possibility could be the LED driver board itself. I'd check for any bad/broken caps and bad solder joints. If not results with that I'd replace the board. Part number for that is 715G4863-P01-000-004S Post some images of all your boards with your question. Maybe we can see something a bit more obvious. Use this guide to post images with your question.
Indice 2
it s turn on no signal and turn of
Indice 0
1 commentaire:
Joseph Renfort not sure if this is a question or an answer. What model is this and what exactly does it do? Sometimes a well formulated question can actually help to fix things.
par
Ajouter une réponse
larry sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,385
