Battery not working after upgrading Hard Drive
Hi all!
I received a late 2011 13" MacBook Pro with a 2.8 Ghz i7. The computer was 100% working and the only problem was that the screen had some wobble to it.
So it disassembled it, removed the screen, tightened the loose hinge screws and put the screen back in. I also went ahead and pulled the stock 750 Hard Drive and installed a Sata III SSD.
I booted it and everything looked great until I noticed that the battery wasn't charging. In System Profiler the battery shows normal condition with 90 cycles. If I remove the MagSafe, the computer turns off. Without the MagSafe plugged in, the battery button on the side of the Mac doesn't light up anything.
So I reset the SMC and the PRAM. That did nothing. I redid my install process for the hardware that I touched. I left the battery unplugged for an hour. I'm still stuck. When I unplug the MagSafe, the battery lights on the side flash for a second. I know that the battery worked normally before I messed with it. The same charger works normally with my other MacBook.
Any ideas?
