Here is the thing. Acer will switch to battery when the battery is fully charged.
This will switch the sleep, and Power settings to battery mode, despite of the fact that you have it plugged in with the Charger that was included or not.
This means that if you have the settings between battery, and "plugged in" set differently, the Acer will default to the battery sleep settings.
The switch control for this is in the hardware, not the software, and not user servicible.
It causes display glitches and disrupts both Bluetooth, and Wi-fi as it switches between battery, and charger.
It will do this even if both sets of settings, are the same.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
2 commentaires
are you using the original charger it came with?
par Goulithum
My aspire is two days old!!!!! Black screen????
I'm just going to return to best buy.
Was soooo wanting the blue light filter.
Does this problem go away??????
par K Easton
