Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Annoncé en mars 2015 et mis sur le marché le 10 avril 2015, le Galaxy S6 Edge est la version à écran incurvé du tout nouveau téléphone phare de Samsung.
Can I get samsung s6 edge to come out of ODIN MODE?
My phone will not switch on. I have tried to press the volume up + power + home key and also volume down + power + home key. My phone only goes to a blue page which says 'warning.. A customised os can corrupt your phone etc...' and 'press up to download' or 'down key to cancel and restart phone'. When I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key it will turn to a page saying downloading and will stay stuck on this page for hours. I have tried a number of combinations but nothing has worked. I cannot plug into a computer or go into samsung as I am on vacation on an island. I also cannot pull the battery out as I have a s6 edge and if I do unscrew it will void my warranty. Can anyone please help?
Répondu ! Afficher la réponse J'ai le même problème
Indice 24
12 commentaires
after hard reset my device goes into odin mode and restart what i do
par
I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key .
par
My phone will not switch on. I have tried to press the volume up + power + home key and also volume down + power + home key. My phone only goes to a blue page which says 'warning.. A customised os can corrupt your phone etc...' and 'press up to download' or 'down key to cancel and restart phone'. When I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key .
par
whay if i disable usb seeting on my phone then also the reset factory and the laucher of the phone and its system UI shut down automatically ..how can i fix this please help me.. :(
par
maybe my chace is on with ODIN mode but don't how .. please help me lol
par
Voir 7 commentaires en plus
Ajouter un commentaire
12 Réponses
Solution retenue
Press all buttons at the same time and hold them.
Indice 154
58 commentaires:
Thank you mine was stuck in this mode and I'm fairly new to the android world and this saved my butt majorly!!!
par
love you brother thanx a ton
par
Wow thanks man
par
thanks man, saved me
par
worked for me nice one dude
par
Voir 53 commentaires en plus
Just hold all the Buttons on the same time power button volume up volume down and home button
Indice 22
1 commentaire:
my power button is stuck and doesn't work
par
get into download mode then hold volume down, power home and the phone should power off. If it won't power back on try holding power and volume down for like 20 sec, it may boot normally.
Boot into recovery power volume up and home and try clearing cache partition (wont delete your files)
then in recovery try factory date reset (will delete your files)
finally if all else fails flash the stock rom (make sure same version or newer than you are using can't go back) using odin
Indice 10
2 commentaires:
THANK YOU SOO MUCH BUDDY !!
You saved my device ! i was worried BADLY ! I was trying to install new firmware on my android ;/ thanks anyways buddy :) God Bless you :)
par
vol up+vol down+power+home not work for me, power+home also not and if i go to vol up or down+home+power phone goes to Odin mode, i need to factory reset coz i forgot lock pattern. please help if possible.
par
Hold Power + Home 15 seconds (Hard reset)
Hold Voume Up + Power + Home until recovery boots.
If this doesn't boot recovery mode and your phone is stock and untouched take it back to Samsung.
If you've flashed CFW/repaired it you're going to have to put it into download mode (like you were stuck on) and flash OFW via Odin.,
Indice 6
1 commentaire:
You are like God for me you saved me from my parents as I do this is mistake
par
Thanks a ton. Verified! It Works! Press all the buttons Vol up + Vol Down + Home + Power and hold them!
Indice 6
2 commentaires:
Thank you sir
it s work. do it Valium UP and Down , home , and power key for five seconds . its work. thank god and thank you
par
It worked for me. Thank you so much :)
par
https://www.youtube.com/watch?v=bii27UQY...
Indice 3
1 commentaire:
When I do all 3 it go to maintenance boot mode
par
Try this.
Press and hold together "power button + volume up + volume down + home button" for about 1 minute and your phone will reboot to nomal.
Indice 3
4 commentaires:
When mine reboots it is in another language. How do I change this??
par
Thank you sir
par
Its not working for me
par
Hi, sorry for late reply guys.
Sometimes it takes more time and need to press and hold for about 1 minute.
If this does not work then wait for your battery to drain completely or bring it to your local technician.
par
ive got a samsug j6 can someone tell me how to fix it
Indice 1
I yanked the battery out of my Note 2 when it did that. Then opened up Safe Mode by holding volume down as it powered up and removed some files that possibly were corrupt
Indice 0
3 commentaires:
I yanked the battery out of my Note 2 Then restarted my phone in Safe Mode and uninstalled some apps I downloaded from Google Play that had embedded malware and its been ok since.
par
can anybody help me please?
par
i was trying to download iodine apps for my samsung galaxy s6edge plus but i cant download it
par
So sometime this type of situations occurred. Just Install a firmware to your phone. Flash with Odin. But it may reset your phone!!!. After you phone will work properly. Be sure a right firm to your phone. 100% guaranteed. If you have any or queries. Please email me at vineil91@gmail.com. Best of luck... :) :) :)
Indice 0
1 commentaire:
Hi i cant get any of the above to work?help pls
par
I know this board is old, but I'm having this problem but none of these options work. I can get to the blue downloading screen, but when I push the button combinations on that screen it just goes black and does not boot up.
Indice 0
3 commentaires:
So does mine do you know how to fix it?
par
I had to repeat the process a few times before the volume down to restart phone option brought up the black and white Galaxy S6 screen to restart. However, now it keeps looping that screen and not actually rebooting. Keep at it!
par
Hold the power and home button together for 15 seconds
par
Still stuck. Tried every example that was given on this page. Took the pbone back to the Sprint store where it was originally purchased from only to find that the techs there didn't know how to fix it. So now, Im just sitting on a $800 device that won't power on.
Indice 0
Ajouter une réponse
hajera sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 55
Total : 179,415
