Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The NutriBullet by the makers of Magic Bullet is a personal blender that is self-contained and simple to use. It includes an electric blender base with a number of attachments for the user and offers a healthy alternative to blending food by breaking down ingredients in their most nutritious states.
I need to replace the swich which.
One of the activators has been forced while it was stuck. This resulted in the perforation of the top of the small plastic cylinder which holds a spring. As a result the lach is loose and does not play its role of actionating the switch. I need to buy the broken parts. Where can I find it ?
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
1 commentaire
Abdel add some images of what and where it is broken. Use this guide Ajout d'images à une question existante to add those
par
Ajouter un commentaire
3 Réponses
Solution retenue
I dis-assembled as per insstruction, and found one of the two activators to be broken. Ordering and receiving can take some time, so in the interim, I cut the red and black wires and marred them together. The activators are wired in series so that works well until I get another.
Indice 1
1 commentaire:
Called the service number. They will not sell or provide the springs or switch parts to repair. You can buy an entire base for $50. NO THANKS!!
par
You may contact Nutribullet Customer Service Department at 855-346-8874 for assistance on using the product or warranty service. (Mon– Sun, 9am–8pm EST). You will be required to provide the barcode and serial number located underneath your Motor Base
Indice 0
1 commentaire:
Jose Rivera, your response does not answer the question at all. ifixit is not about referring to the manufacturer but about how to fix it yourself. Ever tried to get the manufacturer to fix their appliances.?
par
Doesn't look like you can buy replacement contact switches easily and online - I think wiring the switches in series will prolong the life of the blender without compromising safety.
Indice 0
Ajouter une réponse
Abdel sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 2,376
