Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Commercialisé en janvier 2015, le portable XPS 13 se veut un concurrent du MacBook Air, avec un "écran sans bordures " et une option de mise à niveau à écran tactile.
Does anyone know how to tighten the hinge on this?
My xps 13 (2015) is making cracking noises along the hinge, and i think thats because the hinges are loose. Anyone know how to tighten it?
Répondu ! Afficher la réponse J'ai le même problème
Indice 8
7 commentaires
Hi, I am having this issue as well. Could you tell me how you removed the cover?
par
I have the XPS 15, which is built very similarly. I'm also having this issue. You need a small set of torx screwdrivers to open up the back. I found a good set on amazon a while back for around $5 I think
par
The trick is to find the screw under the service tag flap
par
Anyone tried isasukexd's answer and still have this wobble?
par
The dell XPS is famous for the loose hinge, then. My XPS L321X (2012) also have the issue.
Yes, the brackets under the backplate (screwed onto the chassis) can be loose, but it's not that loose. The screw that is the loosest is the one on the display.
How to tighten that?
First, open up the cover (like you are using it)
Use your fingers, pinch the top and bottom sides of the plastic part (on the screen). Then pull toward you. (away from the screen). A plastic tab on top should reveal.
Close the screen (like you are done using it). Use your hands, gently lift up the plastic part. Antennas should be connected to it. The screws are Philips white (can be black) ones behind the display cable and the antenna.
par
Voir 2 commentaires en plus
Ajouter un commentaire
1 Réponse
Solution retenue
Ive fixed it! If anyone else with an XPS 13 is having this issue, take the back off and tighten any loose screws on the top left and right, where the hinge is located.
Indice 2
Ajouter une réponse
isasukexd sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 30
Total : 13,333
