repair cost of my tablet?
What could be the repair cost of a galaxy tab s 10.1 inch and where canni get it fixed?
Haris, that is a big depends. You did not tell us what needs to be repaired. Also, not quite sure which Tab S you have. I only know the 8.4 and 10.5. Since this is an important detail, you need to clarify this
That is a pretty expensive repair but it is a good tablet. I would suggest that you replace the complete screen assembly. This will be the easiest for an inexperienced repair person. The part is available at places like this. Here are the disassembly instructions ==>>Samsung-Galaxy-Tab-S_SM-T805.pdf<<== total cost around $200 USD if you do it yourself. As in where else to get it fixed, that will depend on where you are located. You can always try a internet search and see what you come up with.
HI there I have samsung tab s 10,5 sm t805 I want to replacement lcd screen my tab it is with sim card any different with that let me know please thanks
Hi,
For Tab S 10.5 Glass only repair costs 100 Eur.
It takes atleast 3 hours of work + 20 Eur materials.
Best regards
It will not charge so need where charge fixed. How much would it cost for u to fix.
Can u please fix the charging part in my Samsung Galaxy tablet?
It can be fixed if there is one of those problems:
1. Usb port damage
2. Battery problem (the most common problem)
3. Battery connector solder problem
4. Power IC problem
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 4,293
4 commentaires
Sir the model no. Is SM-T805. Only the screen is smashed as the touch and speakers are working perfectly fine and the screen isnworking fine. It only needs glass repair. If you can give me you ID i will email you the pictures of the current state.
par Haris
Haris, that would be a Tab S 10.5
par oldturkey03
So what would be the price? Any idea?
par Haris
@200USD if you do it yourself
par oldturkey03
