Aller au contenu principal
iMac startup stalling at 30%.
Hi my iMac is stalling during the startup process. Using any of the following methods the result was the same: progress bar gets to about 30% then stops progressing.
It has been left overnight in this state.
I have tried from built in HD, external usb HD and yosemite installer on thumb drive.
I have succesfully booted a macbook pro using the iMacs built in hard drive in target mode as the startup drive for the laptop.
So it does not appear to be a drive issue!
In verbose mode starting from recovery partition (on a cloned ext usb hd) it stops at:
In verbose mode starting from tested clone of internal hd it stops at:
Safe mode yields the same result.
In single user mode I can run fsck. No improvement.
Is this possibly a pram battery issue?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
I should also note that I swapped back in my original ram just in case that was an issue but this made no difference.
I am trying to locate a copy of AHT for this machine to see if that will run of a thumb drive.
par
I am now going to look at a newer iMac and see what is supposed to happen after wifi loads in verbose mode.
par
Ajouter un commentaire
1 Réponse
Solution retenue
Try running AHT from the original system installation DVD.
Indice 0
2 commentaires:
Sadly I do not have those. Every install since and including Os 8 here but not the model specific ones for that particular machine.
par
Is there another way to run AHT on this machine apart from System install discs?
par
Ajouter une réponse
Dickon sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 2
Total : 115
