What OS are you using? The issue is software, not hardware, and the fact that earlier versions of OSX and the related Airport utilities aren't able to deal with modern encryption protocols. If you have a 366MHZ or 466MHZ clamshell, then most likely it's a model compatible with Tiger 10.4. Upgrade to Tiger, and your problem will be solved. Basically, if your machine has a Firewire port, it's capable of being upgraded to Tiger, and if it doesn't, it isn't.
I haven't worked with clamshells in a few months so my knowledge is rusty, but I believe you can also use Panther 10.3 with PWA Personal as long as you update it to the most current version of the Airport utility. Panther (from what I remember) may not have a "Software Update", so it's a matter of seeking out the most current version from the Apple site that is compatible with Panther, downloading it, and installing it, which can be frustrating. Again, though -- you have a capable machine, so get Tiger and you're all set. Having Tiger will also let you use a plethora of software that won't work on earlier versions of the OS, so it's worth it for that reason as well.
Also, what router and what version of the router do you have? Many modern routers are now set by default to WPA2, which won't work with the standard Airport card at all (although it will work on an Extreme). If you do have Tiger 10.4 running, the solution may be to go into your router and change the encryption from WPA2 to WPA Personal.
As Deb mentions, you may be able to get away with using WEP, but WEP is very obsolete at this point and can easily be cracked, so I wouldn't recommend reducing your security to that level.
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
