I just completed replacing the front and back , front broken, back just scratched and ordered a replacement battery as wellas run time had decreased significantly in 2.5 years.
May as well make the 4s look new again
I experienced ALL the symptoms listed previously, searching and the like but none of the remedies worked for me!
I noticed that it would go to Apple screen, off, then recycle over and over but when connected to my iPad charger it would eventually get to the home screen,...DISPLAYED 100% and still charging?".
Since nothing else worked, I decided to try putting the old battery back in and,,,IT WORKS!
In my case a defective new battery was the cause!
Strange but true!
Thought I[d pass it along to maybe benefit others as I suspect it was erroneously displaying 100% then shutting down due to lack of power.
Odd that it had the same symptoms though. 1 other thing, my date was also off, back to Dec31, 1970 but my WiFi was greyed out and could not select.
Maybe I should have treated like my old Cube, 1 mod at a time!
Just didn't consider a new back and battery could cause such problems.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
4 commentaires
I also got this problem,
Does Any one who can upload a pic to help me out?
Which mounting screws?
== Update ==
any one solved this problem?
par Y L
Any updates? This is the same problem I have after replacing the lcd screen. Wifi works. Youtube doesn't want to connect either.
== Update ==
Any updates on this?
par Quan Lin
This is a great thread, I'm having the same problem, but neither my service, wifi or Bluetooth are working, I'm going to try this tmrw and I will let you guys know how it goes. Keep up the good work, best info I've found after searching the web for nearly 2 days :)
P.s. my little blue inductor seems to be ok, so am gonna do a full tear down and build it back up first, to see if the problem can be solved without messing with the inductor. Wish me luck :)
Danny
par Danny
I myself am having a hard time getting the iphone 4 back up and running. I replaced the bottom black portion which contains all of the parts needed for reception. I still cannot get service, I got service for 3 days and then went to searching and no service repeating. I replaced again and got a brief 3g symbol which disappeared quickly. I have cleaned all contacts,from oily fingerprints/smudges. the cable that connects to the board is connected as well. along with the the little blue fuse intact which ive read causes issues if knocked off.
Please help!
par Tony
