Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Support pour la série CQ57 des ordinateurs portables Compaq.
will not boot up
After pushing the power button, it shuts itself off 3 to 5 second after pushing the power button
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
3 commentaires
do you get any error screens? does it get to the boot screen ? how far into the boot do you get
par
I can get to the boot screen sometimes and it still just shuts off with a little popping sound
par
I will try that thanks
par
Ajouter un commentaire
3 Réponses
Solution retenue
It could be a problem with static discharge , if so do the following.
1. Disconect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds , then release for 30 sec and then hold down for another 30sec
4. Plug in power ,replace battery and power on laptop.
If this causes no Joy try this.
Remove memory and reinstall one stick at a time, if there are more than 1 dimm of ram, try each stick in each slot one at a time to see if the memory is ok and to determine if one of the memory slots is bad.
Hope this helps
Indice 4
1 commentaire:
I haven't ever opened up a laptop, isn't it risky?
par
Fantastic, who's a clever boy then? Problem solved on only the second page. Laptop going off after 10 seconds. Thank you so much.
I wonder if you could help me further please. I have been given an Eee small lap top. Unfortunately the owner didn't tell her husband the password before he died so I can't get into it. It turns on OK and then stops. I have all the cables and books etc.
Regards and thanks again. Alan.
Alanbeasley@virginmedia.com
Indice 0
get error code 00000000.0E will not reboot to factory mode i dont have cd to reboot
Indice 0
1 commentaire:
I have not opened my computer for almost 1 year and it is not strating and the charger light is not lighting too
par
Ajouter une réponse
raishard sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 29
Total : 5,027
