Aller au contenu principal
Fitness and sleep tracking band that also displays caller ID information when paired with a smartphone app. Released in November 2014.
20 questions Voir tout
What kind of screwdriver do you need to open the back?
Hi I'm trying to fix my Fitbit charge, I'm pretty sure that is not working anymore because a water damage. If anyone knows can kind of screwdriver do you need to put apart the screws from the back I will be very thankful.
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
4 commentaires
I am wondering that too! Did you ever find out? I have exact issue where I went in the lake and it died after that.
par
I've since verified that it is indeed a T3 screw. My Charge fell apart, and my wife's Charge randomly stopped working. No water damage, it just died.
I thought it was the battery, so I opened both up to swap the batteries, to find it wouldn't be quite that easy...the batteries are soldered to the board. And the wires are tiny.
Earlier this evening, I got around to de-soldering the batteries so I could swap them, only to find my wife's Charge still didn't work, even with a known good battery. It was just dead.
So, I reattached the battery to my board, and installed that into my wife's band. Since it was different internals, I had to do a factory rest in order to pair the Charge with the wife's account.
Just a note, once you take the screws out, you'll likely need a spudger to finish removing the back. It was a bit of a PITA.
Also, once I got mine apart, I found that some of the screw holes in band's frame were broken. When I put it back together, I actually had to glue it shut.
par
Fitbit customer support are really good, i've had a couple of similar problems with my Charge HR, and after 5mins of talking to the online chat support, they have sent me replacements. Might be worth a try if they break again!
par
Weird, my Charge HR has Torx T2 screws.
par
Ajouter un commentaire
5 Réponses
Solution retenue
See if this guide helps: Fitbit Flex Teardown
Indice 1
1 commentaire:
That answer is for a flex, not a charge.
par
According to this Charge HR teardown, it's a T3 Torx.
Fitbit Charge HR Teardown
Indice 1
1 commentaire:
This must be a new post of the teardown for the HR model? I didnt see that before when I posted the question thank you!
par
I can confirm that it is a T3 Torx screw in the Fitbit Charge (NOT CHARGE HR). Here is a replacement battery with all of the necessary tools (including T3 Torx Screwdriver) for the repair:
Battery for Fitbit Charge
Indice 1
Same one as the bottom of an iPhone 6, very small star shaped one, not sure of the name sorry.
Indice 0
Fitbit Charge and Charge HR are different beasts. My Fitbit Charge (non-replaceable wrist band) used T2.
Indice 0
Ajouter une réponse
Luis Blanco sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 12
Total : 15,155
