Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Une tablette de la marque de Google avec un écran 7 pouces. Cet appareil ne necessite qu'un outil d'ouverture et un tournevis pour être réparer.
Nexus 7 frozen tablet
one app frozen the table and cannot exit of that
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Solution retenue
Just in case others are reading this and don’t understand the types of “Resets”;
Hard Reset and Factory Reset. What’s the difference?
First:
What to do before you reset the Nexus 7 (2013)
Backup, backup, backup: if it’s important to you, make sure you’ve got a backup copy somewhere safe before you reset your Nexus 7 (2013). Also make sure you’ve got a note of any crucial app passwords, because post-reset you’ll need to set them up again. Also, make sure you’ve synced with your Google account so that all the online data Google has for your tablet is up to date. That’ll make restoring your Nexus much simpler.
Hard reset and factory reset. What’s the difference?
There are two ways to reset your Nexus 7 (2013). The first option is a Factory Reset, and the second is a Hard Reset. So what’s the difference? A Factory Reset erases all of the data from your device, and while any data stored in your Google Account will be restored, all of your additional apps and their data will be removed. A Factory Reset shouldn’t touch any data stored on the internal SD Card, but a Hard Reset will wipe that too. Factory Reset is called from the Settings menu, while a Hard Reset is carried out in Recovery Mode.
How to reset the Nexus 7 (2013) using the Settings menu (factory reset)
Once you’ve checked your backup, you can reset your Nexus 7 (2013) via the Settings menu. To do that:
  • Open Settings
  • Under Personal, tap on Backup & Reset
  • Under Personal Data, tap on Factory Data Reset
  • Tap on Reset Tablet
  • Enter your PIN, pattern or password if prompted
  • Tap Delete Everything
  • Reboot your Nexus
How to reset the Nexus 7 (2013) in Recovery Mode (hard reset)
There are a few key issues to bear in mind before you do this. If you’ve reset your Google account password, you can’t do a factory reset for 72 hours after the change. And on Android 5.1 onwards, there’s a security setting that means you can’t re-activate a reset Nexus 7 without providing your Google username and password immediately after the device resets. Here’s how reset the device, straight from the Google mouth:
  • Turn off the Nexus
  • Press and hold Volume Down and then press and hold Power until the tablet turns on. You should see the word “Start
  • Press Volume Down twice to highlight Recovery Mode. Press Power to confirm your selection
  • Hold down the Power button and tap Volume Up.
  • Press Volume Down twice to highlight Wipe Data / Factory Reset and press Power to confirm
  • Press Volume Down 7’s to highlight Yes - Erase All User Data. Once again, press Power to confirm
  • After the reset is finished, reboot your device.
If your Nexus appears to lock up during any of these steps, you can restart it by pressing and holding Power for a few seconds.
Indice 1
1 commentaire:
I did a hard reset like teached by Zfix (thank You) and the tablet come back at life!
I only was pressing the power button! Silly Me!
Thank You All!
par
I bought for $20 my third Nexus 7 (2013) on 2021! It’s a model that I’ve had before and I like.
I almost went mad trying to fix the frozen apps. I tried to hard reset twice but also update Google Services (the tablet kept asking) so once that’s done the tablet seems doesn’t handle the update and the problems started.
So… in my case:
1) Hard reset: volume down + power for 10 secs > then you will enter Recovery Mode > then volume up and power button for 2 secs and release for the menu to come up > Factory Reset / Wipe Data.
2) Enable app install from unknowk source from the settings menu.
3) Download apkpure!
4) Open apkpure and download and install for example Youtube.
If after this step you can open Youtube and watch videos (even slow at the beginning) you can use apkpure to upload the apps you may use.
Do not upgrade Google Services cause that blocks and null the entire system.
Indice 0
This is a hardware issue with a simple fix. You will need to remove the back cover. Once cover is off, you will need to remove and reseat the larger ribbon cable. This will highly likely fix the issue. The N7 is a beast of a tablet. And had wireless charging back in 2013.
Indice 0
Ajouter une réponse
eduardosanchez656 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 18
Total : 1,458
