Aller au contenu principal
The Dell Inspiron 15-7537 is a 15.6" touchscreen laptop with an i5 core processor.
20 questions Voir tout
How do I disassemble just the screen?
I have a Dell Inspiron 15-7537 with a touch screen. the entire screen shows tiny dots (for lack of technical term). Connecting an external display works and looks perfect so I know its not the video card. The dots show on boot up too. I can press to the left of the dell logo on the screen and it gets a little better. Im thinking maybe its a bad cable or loose cable at the inverter (given that the inverter is behind the dell logo). I can't find anywhere on the net where it explains how to disassemble just the lcd screen or if its even possible. It doesn't have a plastic bezel like many windows pcs. the screen assembly looks more like whats on a macbook pro. anyone know
1. what may cause these dots and how to fix it? or
2. how to get in to just replace the touchscreen digitalized or lcd inverter?
thanks.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
tech4eleven the dots from your description are most likely stuck pixels. there is not really a repair for it, so you'll be looking at a new LCD. Check to see if this video will help you.
Indice 0
1 commentaire:
I can see the dots move slightly though and the dots are on every part of the screen. Like this image : http://design.ubuntu.com/wp-content/uplo... but those dots are a TON closer to each other and it covers the entire screen and can be seen on top of everything.
I've seen that before before. Just shows how to take the screen off the rest of the laptop. Doesn't show how to take the screen apart. Ive seen just the touchscreen glass for sale so I assume its possible to take the screen apart but just haven't seen how.
par
Watch this - https://youtu.be/GojDReje_ng from the 3:30 mark.
Indice 0
INSTALLATION & REPAIR INSTRUCTIONS:
- STEP-1: Avoid static discharge by grounding yourself using a wrist grounding strap or by touching a bare metal surface like a connector on the back of the laptop and remove all of the power including the battery and power adapter.
- STEP-2: Slide the battery latches towards the outside of the laptop until they click.
- STEP-3: Follow link to Read More - http://ppci.me/b/FYAJ
Indice 0
Ajouter une réponse
tech4eleven sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 16
Total : 4,239
