No backlight in keyboard after upgrading to windows 10
Hi All.
I have a problem with my Samsung NP700Z3C-S02 laptop after installing windows 10.
I have not been able to use the fn-keys or turn on the backlight in my keyboard.
I have tried searching for the problem, but the only solution i found was to install the program: Samsung Settings.
When I install the program windows blocks it with this warning: "This app has been blocked for your protection".
I found a solution to avoid this, by opening the administrator account and install the program from there - again no luck.
Do you have any ideas or things I can try?
Looking forward to see your answers.
Niels.
12 commentaires
Dear All
i do have same problem after instaling windows 10.kindly follow the below link
you will get solved the problem
[http://www.samsung.com/uk/support/catego...
thank you
Shivakumar
par raviralashiva19
Could you be more precise! I don't want to look into all the rubbish before hitting the solution!
par Reidar Erke
Just download SW Update - http://www.samsung.com/us/support/answer...
and update drivers
My NP900X3F-G02SE in Win 10 all keyboard FN functions started working
par Andres Koor
It is quite simple, do the following:
1) Make sure you have downloaded Samsung Settings App.
2) You have to have Samsung Update Tool installed on your PC.
3) From Samsung Update Tool, Go to App Subsection, beneath Drivers on the left.
4) Look For Samsung Setting Expansion Pack, download it.
5) Keyboard Back-light Feature supposed to work automatically.
6) If 5 not the case, please go to Samsung Settings, on the left select Input, and then Turn on Keyboard Backlight.
That is it.
par Massoud Alowihan
Still not available for the 700 series as of end of June 2018...
Screw you Samsung.
par Henry
Voir 7 commentaires en plus
