Aller au contenu principal
The Kenmore Elite HE3 is a washing machine by Kenmore.
661 questions Voir tout
meaning of OE code
getting OE code and does not drain/spin
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Solution retenue
@ronhurley the error code "OE" is a "Drain error " and it is initiated by your washer not having fully drained in 10 minutes. Most common cause is a clogged filter. Check your "coin trap" filter for retained objects, like missing socks etc.:-)
To clean it
1. Take off the lower front panel
2. Turn the pump filter cover counter-clockwise by hand and remove. Place a bucket or pan underneath it since you will get water spilling out of there.
3. With a set of long pliers, remove the filter. Clean that of any debris etc. and replace it when cleaned.
4. Replace the filter cover and lower panel.
The other thing that could be going on here, is that the drain pump is not working and needing to be replaced. The service manual will have instructions on how to do that. There is also a decent video on here.
There will be plenty of water. So please make sure that you have lots of buckets and towels etc. to catch the water. It will be a stinky, dirty flood
You can download the service manual from from here.
Indice 3
6 commentaires:
Have cleaned outf ilter blow hose clean still same fault
par
I followed this and didn’t fix anything. I am guessing the pump is clogged or not running at all...good luck
par
Worked for me , I just hope it stays working! Thanks
par
I had to replace the drain pump, 20 something bucks on Amazon. Not to hard but can be challenging for some. Fixed the problem.
par
Thank you so much. This did the trick!
par
Afficher 1 commentaire en plus
Worked like a charm. My kids are trifling and don’t clean out their pockets when washing. Thank you for the good advice
Indice 1
Ajouter une réponse
rhurley52 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 56
7 derniers jours : 447
30 derniers jours : 1,948
Total : 100,607
