Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L’Atari 2600, ou Atari Video Computer System (VCS), est une console de jeux sortie en septembre 1977. La 2600 utilise un processeur MOS Technology 6507 et des cartouches ROM pour stocker les jeux.
Sport/Racing Controllers not responding correctly when wheel is turned
Hi All,
Just wondering how to fix the 'wheel' controllers for Atari 2600 systems. Both sets usually have the same problem, eventually they seem to wear out and the buttons will work fine, however when spinning the knob (or wheel), you might get a jitter at best as a response from this joystick.
If anyone could enlighten me, that would be great! Many thanks in advance!!
Mike E
EDM, AB, CA
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Solution retenue
My guess is that the contacts on the wheel have either corroded or been built up with dirt.
Pull the wheel off of its peg, and unscrew the washer holding it in place (a pair of pliers will get it open). Open the back case with a Phillips screwdriver, and pull out the variable resistor. If you look at the underside of the resisitor mechanism, there are four metal tabs. Bend them out of the way, and lift the cover off. Inside are some metal rings, these are the contacts. You can clean them with some rubbing alcohol, or remove them and brush them down with some steel wool to remove corrosion.
Good luck, let us know how it works out.
Indice 4
2 commentaires:
Thanks for the quick response! I will be out of town for the next couple weeks here, but I will post back once I get the chance to crack these open.
par
Ajouter une réponse
Esso sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 22
Total : 2,639
