Thanks for the responses.
See here for the photos: iPad Repair photos
A friend had been having trouble with her iPad 3rd Gen digitizer occasionally not responding to any touches or swipes. Several times over few months I put the iPad in Recovery mode (using iTunes) and the digitizer starting responding again. Finally the digitizer no longer responded even after being put in recovery mode or after several hard resets (holding "power" and "Home" buttons for 10 seconds). So this time I performed a Restore from iTunes hoping that would clear up any problems. However, the digitizer still didn't respond and the iPad was stuck on the "Hello" screen (photo 1).
I then ordered some tools and used them to take the iPad apart using the instructions on iFixIt.com. I cleaned the contacts with isopropanol and reseated the cable as shown in photo 2.
Still the digitizer did not respond. The cable looked good and un-cracked. So I decided it may be a bad digitizer ordered a replacement digitizer. Upon receipt, I opened the iPad again, removed the old digitizer and connected the new one. Photos 4 and 5 show the white line and the contact sides of the connector after installation.
Again, upon re-starting the screen cycles through the different "Hello" messages (Photo 3) but I can't "slide to configure" because the digitizer doesn't respond.
I'm convinced something's wrong on the logic board. The LCD and all of the buttons seem to work fine and the connectors and cables look good. Given it's age and model, I don't see this iPad being worthy of a logic board replacement.
I'm ready to forget about it and sell everything for parts on eBay.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
Can you show photos of the problem? What is that white line?
par Mimi
