Aller au contenu principal
Sony’s 20.1 megapixel camera designed to capture still images and video recording. Model number: DSC-W800.
12 questions Voir tout
Why will my device not power on?
Why won't my Sony Cyber-shot DSC-W800 power on? When pressing the power button nothing displays on the screen and the device seems to be unresponsive.
Could this be a battery issue or something more serious that would require repair?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
2 commentaires
يرجى توضيح أكثر هذا قليلا
par
@tcampo what happens when you do replace the batteries? does it then turn on?
par
Ajouter un commentaire
1 Réponse
Solution retenue
There may be several reasons why your device may not be powering on. Following are the common ones:
  • The battery may not be sufficiently charged. It may discharge automatically if not used over a long period of time. In this case, simply charge the battery. Also, check to make that the battery is inserted in correct orientation.
  • The battery terminal may not be clean. You may clean the terminal with microfiber.
  • External temperature also effects the way the camera functions. Thus, make sure to not use the camera when the temperature is above or below 0-40° C. Condensation might occur if the camera is moved from extremely cold temperature to a warm environment, which could prevent the camera from functioning properly. In that case, let it come to room temperature and allow the condensation to evaporate naturally.
  • For more information, refer to the troubleshooting page.
Indice 3
Ajouter une réponse
Thomas Campo sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 19
Total : 1,537
