Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tablette haute performance d'Apple.
Cracked screen iPad pro Options
I have been reviewing options to replace a cracked iPad pro screen.
Ifixit is always my one stop, but I am getting conflicting information and wanted to ask the question here.
Basically the iPad pro works but the screen in 60% cracked thanks to a coffee cup which decided to fall out of a cupboard and right onto the iPad.
Anyhow, the ifixit site mentions "part requires micro soldering" but when I watch YouTube videos "ttp://youtu.be/StBxazGQLS4" I see a simple push connector.
What am I missing? I simply want a display assembly for my iPad pro.
[produit lié absent ou désactivé : IF323-000]
Note. The iPad edge may also have a dent, is there a fix for that?
My last option, because the iPad works fine is to purchase a $35 glass screen protector and call it a day.
Répondre à cette question J'ai le même problème
Indice 6
Ajouter un commentaire
4 Réponses
Réponse la plus utile
Your problem lies in here:
https://d3nevzfk7ii3be.cloudfront.net/ig...
Notice on the above picture you see a small board that the push down connectors are soldered too. On the part you linked that board and it's connectors are not there.
So the part you have linked requires you to desolder that board and reattach it to the new display.
The next logical question is "Can I buy one already attached?" The short answer is I don't know. The daughter board could be married to the main board so you have to keep the originals together for them to continue to work. I would imagine that this is the case taking in the fact that the fingerprint scanner is attached to that board.
My guess is you will need some soldering skill for this repair.
Indice 1
1 commentaire:
You CAN get the screen/digitizer with daughter board attached, from iFixit ($199), I have done it twice now. no soldering required, just follow the guide and make sure you disconnect/block the battery before plugging in the new display.
par
I solder the daughter board to 2 different new displays - the lcd works but i have no touch. I checked the solder several times and do not see an issue.
Indice 0
1 commentaire:
They're definitely fixable as this is a repair we do often. Be really careful getting the chip off and double check your solder work under a microscope.
par
you can get a ipad pro screen replacement here. it is not easy to repair ipad pro digitizer only or change glass, it need special tools etc.
Indice 0
1 commentaire:
Do u repair ipad pro screen
par
Ipad pro 10.1screen damage can u repair
Indice 0
Ajouter une réponse
carsten sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 32
Total : 32,255
