Aller au contenu principal
6ème génération de l'Apple iPhone, annoncé le 12 septembre 2012. La réparation de cet appareil est similaire aux précédents modèles et nécessite des tournevis et des outils pour ouvrir et faire levier. Disponible en GSM ou CDMA / 16, 32 ou 64Go / Noir ou Blanc.
20 questions Voir tout
iPhone is disabled for 24 million minutes
I just pulled out my old iPhone 5 from its box to see in my horror to be disabled for 24 million minutes (4 decades) and its stuck in airplane mode. I tried methods with putting a working sim in there in rebooting 2 times to no avail. I also heard about restoring it but I don't want to lose all my info on it so can anyone help?
Répondu ! Afficher la réponse J'ai le même problème
Indice 7
5 commentaires
Try updating, and after the update has finished swipe up from the bottom of the lock screen and turn off airplane mode from there.
par
how do i make my mintues go faster
par
If you leave the device on earth, then jump in a spaceship travelling at near light speed 'Five years on a ship traveling at 99 percent the speed of light (2.5 years out and 2.5 years back) corresponds to roughly 36 years on Earth'.
par
This worked!!!! thank you!
I have had this phone in storage for years. Now can finally fix it. Thank you!
par
My an iPhone unlock data not problem
par
Ajouter un commentaire
7 Réponses
Solution retenue
What solution I eventually found was inserting a working SIM card into the iPhone and it should get the current date which will reverse the problem of having it disabled for an unreasonable amount of time.
Indice 0
2 commentaires:
What size card did you have to get
par
@Aziza Whitfield the iPhone 5 was the first phone to be released with the Nano SIM card. Make sure the sim is working since it needs to connect to your cell network to update the date.
par
Réponse la plus utile
yes, you will lose all your information , this is inevitable so you may suck it up I'm sorry to say.
here is the process for restore through iTunes which you will need to have downloaded onto your pc/mac/laptop
make sure phone has some charge in it , 20% or more ideally
open iTunes on pc/;laptop/mac which you will have previously downloaded
connect iphone to computer usb port via iPhone charging cable.
hold both the top power button and the main round home button on screen together until apple logo appears
LET GO OF ONLY THE POWER BUTTON , KEEP PRESSING HOME
keep holding the home button until the connect to iTunes logo appears.
then follow the prompts which it will say to update and restore.
you may then have to wait for the update to download which can take some time depending on internet connection.
PLEASE NOTE , if during this time while downloading the software, that it reverts back to your original screen , then wait for the download to have finished which should be at top right of your screen , an arrow.
THEN REPEAT earlier process of
hold both the top power button and the main round home button on screen together until apple logo appears, then
then just follow the online steps again
this will restore your phone to factory settings.
Indice 2
4 commentaires:
This works!!!!!
Thank you.
par
I had the same issue and the solution mentioned above worked .
par
What if your home button is broken and can't connect to Itunes because you have not synced it before?
par
"the iPhone "IPhone" could not be restored. TATSU declined to authorised this image on this device for this user"
help me please.
par
Only by restoring you can have your phone back. If you have an itunes or icloud backup you can retrieve the info you saved, but all the info you haven't backup will be lost.
To recover you phone turn it off and plug into a pc or mac while holding the home button and follow Itunes indications
Indice 1
2 commentaires:
What if you don't have a mac computer or laptop
par
@youneedgod Take it to a local repair shop, perhaps they can help you.
par
I had the same issue here on an iPhone6. Had a broken screen from which the touch functionality only worked on half the screen. Due to this, couldn't enter the passcode properly and had several wrong tries. If that happens it tells you to retry after 5 minutes. The next time, you have to wait 15 minutes, then 60 minutes etc.
So I ordered a new screen and replaced it. In the process I disconnected the battery and reconnected during reassambly. This causes the date to revert to 1st of Jan 1970. Which, yesterday, was 25359778 minutes ago.
I didn't want to restore the phone as we didn't have a recent backup. Also I didn't feel like waiting 48 years to retry.
Finally I just connected to the mac and opened iTunes (not sure if that's necessary). I waited a bit and apparently the phone synced time with the computer. Now I could enter the passcode.
Indice 0
Restore on 3uTools: http://www.3u.com/tutorial/articles/5970...
Indice 0
I had this exact same problem with the iPhone 6. I tried Erik127's method and it didn't work but we put in a new SIM card and it fixed it (by resetting the date from Jan 1970 to 2018)..
Indice 0
If the iPhone 5 is disabled and you can get several chances to try. But you'd better think twice before entering different passcodes, otherwise, the device will be locked with no ability to connect to iTunes.
In this situation, you can use iTunes to restore iPhone system to unlock the device or try FoneGeek iPhone passcode unlocker to remove the screen password.
Indice 0
Ajouter une réponse
TheLoneGamer sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 87
30 derniers jours : 333
Total : 82,563
