Aller au contenu principal
Pour réparer ensemble - Je crée un compte
A 5", 3 pound personal random orbit sander made by Porter Cable and released in 2010
Why is my sander not sanding?
I recently purchased a Porter-Cable 382 at my local home depot. I had been using it for weeks and haven't had any issues sanding down some objects. However I went to use my sander today and it is no longer sanding the surface like it had done so well before. The head is spinning but not sanding, please help.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
If your sander is not sanding there could be a few different problems. First one being you need a new piece of sandpaper, in which case you should replace the sandpaper. Your sand paper could also be too high of a grit making the abrasive surface not rough enough to do any real damage, try gradually using lower grits until the surface begins sanding. If you go too low and scratch marks appear just work your way up to higher grits. Your device could also not be operating properly in which case I would check this devices troubleshooting page to search for causes for various problems.
Indice 0
Ajouter une réponse
jpfoxracing9 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 34
Total : 1,243
