Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Nokia Lumia 920, développé par Nokia et sorti en novembre 2012, utilise le système d'exploitation Windows Phone 8.
Nokia Lumia 920 not turning on
i also have the same problem and always do the same thing by press the volume and power on/off and its works usually. but now its not really work. there are no any response when the phones was charging. it looks died. the hard reset also cannot do anything. whats the problem??!!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
Hi,
Connect the phone to a PC (be sure your cable is working).
Try to switch it on. If the PC recognizing your device 90% you have a SW problem. Try to restore the phone:
Solution à l'erreur du gestionnaire de démarrage sous Windows 8/8.1 et Windows 10
If your PC does not respond when you connect the device, then the problem is hardware, broken USB connector, logic board damage...
Regards.
Indice 2
1 commentaire:
@zfix I referenced one of your you tube videos to help someone just now thanks for the video it was great
par
You try reset factory?
Indice 0
Ajouter une réponse
caercspf sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 23
Total : 850
