when I turn on the camera it say memory card locked
why does it say memory card locked ?
SD cards have a tiny little tab on the left side edge (as seen from the front of the card). When this tab is in the LOCK position, a sensor switch in the camera tells the camera that the card should not be written to, i.e. the card is locked.
This was driving me nuts...after reding your solution I took the card and battery out of my canon ixus and blew hard into the space...Hey Presto! everything works. Thanks dude
Wow just worked thanks mahn✌
it does not work man
Tried what you suggested,worked perfectly,thank you so much.
Thank you, it was driving me nuts as well. Had no idea about the SD being tabbed.
There is a switch on the top left of the memory card. Switch it up.
For me, I think it was my memory card that had a problem. I tried flipping the switch several time and it still didn’t work, then when I tried a different memory card it worked
My experience with the same problem: Card A for Camera A was unlocked (tab in the upper position) and it would still not work after my blowing some dry air into the slot. Tried Card B in Camera A and it worked, so I thought Card A was the problem. Tried Card A in Camera B and it worked. Weird.
Dernières 24 heures : 31
7 derniers jours : 203
30 derniers jours : 933
Total : 101,186
4 commentaires
Thanks so much for fixing a problem that foxed me. All now working perfectly again. Bless you!
par granniechrissie
Hello, I am having a similar issue with my Canon PowerShot SX620 HS but flicking the memory card switch doesn’t have an effect. I’ve also tried three different memory cards and the camera is showing the same error message so I feel it’s probably a problem with the camera itself. Has anybody got any possible solutions? Thank you!
par CRM34
Hi,
I am having a similar issue as well with my Canon PowerShot ELPH 360 HS. Like the previous comment, I have tried clicking the tap on the memory card to locked, unlocked, etc. Nothing happened. I tried multiple memory cards as well, and the message still said "memory card error" and under that: "memory card locked"
My sister has the same camera and this has never happened to hers.
Any help would be appreciated. Thanks!
par Rosie Dulle
Yup: I just bought a new card and when I inserted it the camera said « card error »
After much fuffing about including going back to the shop where I bought it, I found out that what I thought was the card was actually just the card holder and the card was actually I tiny square of plastic which has to be inserted into the card holder. I don’t remember that ever being the case before????
par John Lawrence
