Aller au contenu principal
The Canon PowerShot SD1300 IS is a compact digital camera released by Canon in 2010.
2 questions Voir tout
it was dropped into water now getting lens error message
I have a Canon Powershot SD 1300 IS . Luv this camera.
My friend accidentally flipped it off a table into a bowl of water. I got it out quickly & dried it out. Now I've turned it on the lens extended on its own & I can't get it to retract. And now when I turn it on I get a "lens error message"Help please.
Thanks
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire:
I have the same camera and the lens is stuck and won't move. when I try to move it, the camera shuts off. I would appreciate some help with this.
par
Ajouter un commentaire
1 Réponse
Just a few years late and only answered for completion sake. Who knows? Somebody may just run into issues with their "old" camera. Anyhow....
You will need to have to treat this just like any other water damaged device. For now, you want to stop continuing to try to operate your camera. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your camera using these guides as well as something like this video. Remove the main board. You must remove the EMI shields from the circuit board. After you remove those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide Even so it was written for an Apple iPhone 3G, all the points are still pertinent to your camera as well. While you clean your board etc., check for any obvious damage, like burned or missing components etc. When it is properly cleaned, you must be ready to replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your camera and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad lens since it is uncommon for a lens to fail due to water damage. It may have gotten knocked of track when it got submersed. Take a look on here for some ideas on how to get it back to working condition. If none of those work, use this guide Canon PowerShot SD1300 IS Lens Replacement to repalce the lens. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Image iPhone
Tutoriel
Réparer un dommage causé par un liquide sur un iPhone
Difficulté :
Difficile
1 - 2 hours
Image Canon PowerShot SD1300 IS Lens
Tutoriel
Difficulté :
Modérée
10 - 25 minutes
Indice 0
Ajouter une réponse
Boxxies sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 8
Total : 157
