Aller au contenu principal
Adaptateur secteur pour MacBook, MacBook Pro et MacBook Air. Dispose d'un connecteur aimanté à auto-alignement qui se déconnecte en toute sécurité lorsqu'on le tire. Les chargeurs MagSafe de première génération (2006-2012) ont un connecteur en forme de L légèrement plus épais. Ils sont disponibles en versions 45 W, 60 W et 85 W.
Questions au sujet de 64 Voir tout
Is it normal to have white paste inside charger or something leaked?
I decided to replace a cable in my MacBook charger (old MagSafe). I cracked it open and there is a large blob of some sort of white rubberish paste filling a good portion of the space inside:
I am not sure whether it is a special filling paste or something (capacitor?) leaked. I was not able to find any obvious sorts of leakage.
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
Ajouter un commentaire
1 Réponse
Solution retenue
The white rubbery stuff is indeed a filler, I think it may help conduct heat towards the shell so as to avoid the formation of hot spots in the circuitry. It also helps to keep the components in place, which is a good thing because power bricks are relatively prone to rough handling.
Of course, it also makes the power brick more difficult to repair, but then, power bricks as a rule should be replaced, not repaired. Repair of power bricks by non-experts in particular are not unlikely to present a significant safety hazard.
Indice 5
3 commentaires:
I just replaced the cable by unsoldering the old one and soldering new one. I would barely call it a repair. The place where wires were soldered was not covered by the filler, so it was not hard at all.
par
There's always the exception that confirms the rule ;)
However, one should keep in mind that a carelessly executed repair might compromise the galvanic separation between input (mains!) and output (the equipment being powered, and by extension, your body).
par
Thanks I will keep it in mind.
par
Ajouter une réponse
Andrey sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 86
Total : 4,689
