Aller au contenu principal
The twelfth and final generation of the Cadillac Eldorado was introduced in 1992 as a two-door coupé.
20 questions Voir tout
Diagnosing Driver Side Power Window issue
The driver side window has slowly gone out. I replaced the switch. Passenger side window operates fine using the new switch. Drivers side seems to try to engage and moves 1/8th of an inch. For a while it would go up and down sometimes. Now it is not working except it appears it is getting a power signal. My thought would be a failed window front motor but thought I would ask before replacing using this guide: https://www.youtube.com/watch?v=Q6vyEs4H...
But as autos are not my forte I thought I would ask first.
Or do I need the relay?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Solution retenue
Hey @mayer you might want to check the regulator itself . They sometimes bind and cause the electric motor to run slow till it gets to the point were the regulator wont move at all . It can also bind on the window rails. The tracks can start to bind and cause the motor to slow. When I replace a motor for a window I usually replace the regulator as well .Let me know how it works out for your Caddy
Indice 2
2 commentaires:
That was exactly my thought. i had not ordered the part yet but will now. I wanted confirmation first, thanks. I'll update this after replacing it,
par
@jimfixer I forgot to come back and tell you it worked.
par
Same problem with my 2002 Eldorado but for the life of me I cannot identify a “connector" inside of the door panel. There is a switch on the arm rest which is easily accessed and a two wire connector on the motor, both seem fine. I have squeezed and filed, and framed and twisted both the switch and the 2 wire connector with no results. There is no nut on the arm rest panel and cannot identify a plastic connector twist. Moose
Indice 0
1 commentaire:
I'm sorry, I have forgotten this for now.
par
Ajouter une réponse
mayer sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 12
Total : 7,606
