Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Released September 14, 2012, Apple's EarPod headphones are a new revision to their iconic white headphones. Model number: MNHF2AM/A.
How to fix ripped headphone cords
How do you fix the apple headphones when the cord is ripped?
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
3 Réponses
Réponse la plus utile
If you feel comfortable, get some fine heat shrink, a soldering iron and some solder and solder the proper wires to each other. Put the heat shrink on before you solder (slide it down so that the heat from the soldering iron doesn't cause it to shrink prematurely), then slide it over the repaired area and use a hair dryer, heat gun or lighter to shrink the tubing. Keep in mind that the wires inside are VERY small.
Indice 2
u just put the cord part that's broken in the hole to the device
Indice 0
3 commentaires:
That would short out and kill the phone... -_-
par
It most likely won’t short the phone, but you’re essential just sticking wires blindly into a hole.
par
thxs for helping me
par
Hunter - you mean the cord (the wire) is broken ? Segi's answer is correct.
OR....
the ear-plug has been torn from the wire ? That's not repairable. Do Not plug it in.
Indice 0
Ajouter une réponse
Hunter Bagan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 22
Total : 10,648
