Battery Issues after screen replacement
Hello.
I run a small repair business and have recently come into an issue with the I pad air after a screen replacement.
I have repaired a large number of these with out issue but I have had 2 (my personnel one included) that have caused me issues.
I do checks before all repairs and make sure that the devices charge at least 2%.
I always disconnect the battery before LCD removal.
The screen replacement went smooth. All screws returned to the correct spots etc.
I then check functions again before closing up.
Had no problems but a day or 2 later my own personnel I Pad wont charge past 1% and now my clients I pad just shows the red charge battery symbol and wont boot.
I have restored both and put the latest updates on them.
I use an genuine Apple charger 12W and USB cable and use mains/wall power. I have a few lying around and have tried others with no luck.
Any ideas or suggestions?
Thanks
4 commentaires
I would try reopening the devices and cleaning the battery contacts with an alcohol pad.
par Michael Stefanchik
Thanks. This will be the next step.
par Lee
Hi. Lee. did you fix the ipad? I have exact same issue as yours. i have fixed 100 of them with out any problem. but this one is strange.
par Danyal
I fixed mine. I forgot battery screw. Once I put it back. Every thing was working perfect.
par Danyal
