blacksreen,with fan on and led lights on whats wrong
my laptop wont boot up when booted only the fan runs and the leds lights go on nothing elses
Sounds like the screen has failed.
Fixing the screen yourself is not too expensive but if you take it to get repaired by a repair centre the cost may vary.
i have done that already still no response i have opened the motherboard and there is a hissing sound on it when i switch it on with out the PSU but when i put the PSU in it stops
Could be an earthing issue with the board
how do i fix that if thats the case
You may want to try a static discharge . Try removing the battery and the power supply . Once there is no power available to the machine hold down the power button for 60 seconds. this drains any residual power from the board and allows the machine to boot normally . If this brings no joy try removing one stick of ram from the machine and try booting then switch to the other stick . often when one stick of ram goes bad you get the conditions you describe. if none of this helps then you need to start looking at the display or the video controller
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 181
1 commentaire
@smindlos before you replace anything you want to ensure that it is your screen that has failed. Attach an external monitor and see what it displays. This series of Toshiba had plenty of other issues that could be causing it.
par oldturkey03
