Aller au contenu principal
IBM est la société pionnière de l'ordinateur moderne.
Why do coloured,vertical stripes appear on my R52 Thinkpad screen
Almost 5-7" of the laptop screen gets covered with thin vertical lines on starting the computer.Lines do not appear when adapter is used to connect laptop to another monitor.Is this a 'display' or a LCD problem?Please advise what can be done?
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
4 Réponses
Réponse la plus utile
This is LCD screen failure. You'll have to replace the screen.
IBM/Lenovo laptop repair guides.
Indice 1
Those are raster lines and if the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Some panels have issues with the connector that carries the signals. So check your wiring, connections etc. Your video card itself seems to check out since you have no issues with an external monitor. If none of this resolves your issue, follow LaptopRepairGuy's advise and replace the panel. Good Luck
Indice 1
how to repair vertical line in my ibm thinkpad g41
Indice 0
1 commentaire:
saubhagya, are you asking how to fix it? See Laptop Repair guy comment as well as my own. http://tim.id.au/laptops/lenovo/thinkpad... shows you how to approach it. Good luck
par
I had thin red vertical lines on my screen of my T430 Thinkpad. I solved this by disconnecting and blowing air on the connector and reconnecting the screen cable just next to the right hinge
Indice 0
Ajouter une réponse
Harry sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 5,357
