Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Seconde génération du Fairphone, conçu par l'entreprise sociale du même nom. Sorti en décembre 2015. Numéro de modèle : FP2-XCVR
Why does my phone sometimes just turns off itself?
Sometimes phone turns off and I have to replace battery and turn power on. Why does phone turns off itself ?
Répondre à cette question J'ai le même problème
Indice 9
1 commentaire
I am having the same issue since the very first day I've bought my fairphone. I've sent it back to the company so that they could fix it but it hasn't changed anything. I've also installed the system update but I'm still struggling with the same problem. What can I do?
par
Ajouter un commentaire
4 Réponses
Réponse la plus utile
Some Fairphone 2 devices are suffering from an issue which we call random rebooting – the unplanned and unwanted rebooting of your phone. You have contacted us informing us that your phone is affected by this problem.
We are investigating this issue and fixing it is one of our top priorities right now. Our aim is to come with a solution as soon as possible. We kindly ask you to wait until we have this solution available, and once we have news we will inform you via a new e-mail.
In some cases it might also be related to the use of the 4G network, could you please try to disable 4G and revert to 3G to see if it helps?
You can do that in ​Settings​ > ​More​ > ​Mobile networks*​ > select your SIM card > select ​*3G (preferred)/2G*​ as the the ​*Preferred network type​.
Also, have you tried without any SIM card in your phone? We've seen some old/dirty SIM cards causing similar issues in the past. Finally, have you also tried in airplane (flight) mode?
With a previous software update (the latest is Fairphone 2 OS 1.6.2) we introduced improvements to the device stability. Please make sure that your device is up-to-date (see our guided tutorial on how to update your Fairphone 2 and our related support article if you need more help updating).
If you could give us some feedback some time after having installed the system update, it would help us a lot! We've come up with a https://podio.com/webforms/16109104/1081...=|more detailed form on the random reboots] for you to give your feedback.
We apologize for the inconvenience and thank you for your patience and help.
If you still experience many reboots, contact Fairphone customer support: https://fairphone.zendesk.com/hc/en-us/r....
Indice 3
1 commentaire:
par
I have to open my phone several times a day in order to restart it. Sometimes it even starts an update while rebooting the phone that takes about 15-20 minutes. This is very annoying especially if you are on the road and in need of google maps and so on.
Also the bumper starts to break due to the many times I need to do a forced reboot by removing the battery for a few seconds.
I really tried to spread the word about fairphone, but there is no chance to even hide the shut downs in front of friends since it happens in the middle of showing them something on your phone. I am still about to convince myself from this being an actual great product, but sometimes it is really hard when you are close to throw it out of the window.
Indice 1
1 commentaire:
I agree. I bought the phone because I want to support Fair Trade and encourage recycling etc, the phone worked fine for about 18 months but for the last few months is really frustrating.
par
I have had this problem too. The phone seems to get stuck into thinking that the battery is very low, even though it isn't - hence it keeps shutting down.
What seems to sort it out is removing the battery for 10 mins (i.e. longer time) and then replacing it and fully charging it.
Indice 0
Have you heard about the "piece of paper/card" trick? Some Fairphone 2 have batteries that are slightly too small and so any movement causes the battery to temporarily disconnet. So put a small (0.5cm) piece of paper at the bottom of the battery to keep it firmly in place.
Indice 0
3 commentaires:
Tried that - seemed to work temporarily but after a few days, the same old problem repeated itself
par
Its not a great solution, but you could try buying a new battery, the new ones fit better.
par
I have a new battery and have the same problem. Some one really needs to get to the bottom of this problem otherwise this product will fail.
Couldn't agree more with the earlier comments. I also want to support it too much. At the end of the day fairphone need to fix the first design need first ie functionability.
par
Ajouter une réponse
Mysak Wolfs sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 42
Total : 5,302
