I have previously used about 5 plantronics, bluetooth version 1.0-3.0, love it; but, not this one!
This Plantronics has sensor to turn off once I remove it from your ear. The sensor may not work very well. Once I disabled(off) "Smart Audio Transfer" in setting/sensors&presence, it seems to work, but not much better, microphone still sounds so far away. I don't want to play with all the sensor setting, someone might have better luck.
I download/install the software with my windows 10. I run it, plug in headset, then it ask me to download update; once download complete, you can play with settings.
To download and install MyHeadset Updater:
Go to http://www.plantronics.com/myheadset-upd...
Choose Voyager Edge, and then click Get Started.
Click Start.
Click Download.
Follow the on screen prompts for downloading and installing the application.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
1 commentaire
Fix works for the Plantronics 5200 also! I just applied it. Used black electrical tape to cover both sides holes on the round section.
par Sander ten Wolde
