Charging port not working.
My TDK speaker will no longer charge. The red indicator light doesn't come on. I can sometimes wiggle the wire where it plugs into the back and it will light up, but I have to hold it in that one spot for it to charge. It has now got to the point where that doesn't even work any more. Can this be fixed and if so, where can I order parts for it?
2 commentaires
TDK sucks, no support or warranty. Nothing. Just discontinued the product.
I actually ended up fixing it myself.
It's not the battery. The problem is that when you wiggle the charging socket, over time it gets de-soldered from the circuit board. So you need to solder it back.
Open the unit per instructions on TDK Life on Record Trek 360
Then you have to break the black seal to get access to a small circuit board where the charging socket is.
You will see the issue once you open it, it's obvious. Solder it back to the board and assemble back.
Removing the bottom speaker will help too and make it more convenient to fix.
par ralekseenkov
Hey there, I’ve been having the same problem and am in the process of taking the speaker apart to access to charging port. I’ve removed the clear seal around the box concealing the small circuit board, however it still won’t come off. I’m worried about breaking something if I try and force it. Any tips?
par Landis
