Aller au contenu principal
L'iPhone 5c d'Apple a été annoncé le 10 septembre 2013. La réparation de cet appareil ressemble aux modèles précédents et nécessitent l'utilisation de tournevis et d'outils pour ouvrir. Disponible en tant que GSM ou CDMA / 8, 16, 32 Go / blanc, rose, jaune, bleu, et vert.
20 questions Voir tout
iPhone not powering on
After reballing baceband ic my iphone can't turn on. I think that some component must de-aligned near the baseband and also it seems like there isn't C33 component on the board. Is it possible this to cause the problem and if yes where i can get it from?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
19 commentaires
@toastedc0re post a couple of pictures of your board and your repiar with your question. Use this guide Ajout d'images à une question existante for that. It will allow us to see what you see. Also, how did you reball the IC?
par
@oldturkey03 Added an image. Inform me if you want another one, and thanks for your help!
par
Can you please inform why you reballed it in the first place?
par
@toastedc0re thank you for the image. Any chance you can post one that has a bit less motion artifact? That would make it easier to identify the components
Rep: 31
par
@packinit I tried to reball it with flux and a heatgun as the modem number was blank and imei didn't appear. I had tried before all the "solutions" that i found on the net.
par
Voir 14 commentaires en plus
Ajouter un commentaire
1 Réponse
Solution retenue
I took some pictures of my 5c connector with an electrical microscope. It seems that there are missing to components. But I'm not sure if mine is complet because I also have some power problems other ones. Maybe these pictures help you.
Indice 1
2 commentaires:
Thank you for your answer i'll check it out
par
@hehe0903 from your pictures seems like I am also missing components near the battery connector. Seems like the missing components are more than I thought on the first place :/
par
Ajouter une réponse
georgekarapi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 286
