Aller au contenu principal
The second generation Moto X (marketed as moto X) is an Android smartphone developed by Motorola Mobility. Released on September 5, 2014, it is the successor to the original Moto X released in 2013. Model numbers XT1097, XT1096, XT1095, and XT 1093.
Why does my phone keep on restarting then shutting down again? Help!
For the past two days, my phone has been restarting itself to the Motorola logo, then turning itself off, over and over again. I've tried to externally factory reset it and clear the cache partition. Nothing has worked and it always goes back to the Motorola logo only to restart again. Does anybody have any ideas to fix this?
Note: The night before I put my phone to charge at 3%, but it was charging for the entire night. The next day it was in the condition it is now. Don't know if that helps.
Please help!
Répondre à cette question J'ai le même problème
Indice 2
1 commentaire:
The micro-USB port needs to be replaced.
par
Ajouter un commentaire
3 Réponses
Download the stock firmware and flash it via fastboot.
Get into fastboot mode by holding power+volDown until you see the fastboot screen.
Here is a more detailed rundown of how to flash the images.
https://motorola-global-portal.custhelp....
Indice 0
I would check your charger. What you describe sounds like an extremely flat battery. Plug in a different charger that you know works and see what happens. Otherwise you may have a problem with the charging board or circuit
Indice 0
Probably, the micro-USB port needs to be replaced. UbreakitIfixit, a national chain could fix it.
Indice 0
Ajouter une réponse
Eric Amaro sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 439
