Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La tablette Surface Pro de quatrième génération, sortie le 26 octobre 2015.
Can I replace the hinge or kickstand of my Surface Pro 4
I accidentally stepped on my Surface Pro 4, and one of the hinges on the kickstand broke. Rather than replacing the entire device (I do have a warranty) I would rather try to fix it myself. The left friction hinge still works fine, but is not strong enough to hold the device alone. The kickstand itself is not cracked and would not need any replacement, only the right hinge is damaged.
Thanks.
Répondre à cette question J'ai le même problème
Indice 8
1 commentaire
answer is not even about the hinge, only addresses the easy answer
par
Ajouter un commentaire
4 Réponses
Réponse la plus utile
Changement béquille Microsoft Surface RT
Indice 2
4 commentaires:
answer does not address the broken hinge!
par
not a solution, it the hinge it broken it wouldnt help to put a new kick stand on
par
not any help it is not the kick stand it is the hinge. could not vote you down don't have a rep yet
par
Same comment from me, answer doesn’t address issue of broken hinge, which I also have. From what I could find you either have to tear down the product to remove the hinge or purchase a case with its own stand.
par
not helpful--hinge broken & not the stand
Indice 2
yeah my hinge is broken
i found this
http://www.powerbookmedic.com/Microsoft-...
Indice 0
Hi Grant,
To replace the right hinge, you'll have to open up the tablet. You can do this by following this very helpful repair guide!
Changement charnière de béquille Microsoft Surface Pro 4
Indice 0
Ajouter une réponse
Grant Smith sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 28
Total : 16,160
